Results 1 to 4 of 4
Thread: MMI issue
    Active Member Two Rings noservice's Avatar
    Mar 22 2009
    2000 Jetta GLX, 2009 Audi Q5
    Ithaca, NY
    MMI issue
    While driving today the MMI screen shut off and then the system reboot itself.
    has this happened to anyone else?
    2000 Jetta GLX - Gone
    2009 GTI
    2009 Audi Q5
    Jun 04 2009
    Re: MMI issue
    Yes...but mine was happened like this: When i started the car...the mmi screen just pitch black..along with the buttons...no lights (on the mmi buttons)until like 10 mins.....has this happened to anyone else? Anyone ever talked to dealer about this? Please let us know..thank you
    Senior Member Three Rings Regina_TT's Avatar
    Apr 07 2008
    g/f's 2013 TT Roadster
    Regina, Canada
    Re: MMI issue
    It happened to mine in the first week, but so far only once. I was driving along and randomly lost all sound and picture. It was back up about two minutes later. It's a known issue and apparently it's why none of the first landed Q5's had NAV.
    There is a software update that will be performed at your next service. If your next service will be a while or you are generally concerned, call your dealer and ask about the MMI software update. They should be able to book you in to get it done.
    As a side, if the MMI shuts off and does not reboot you can manually reset it. (Not unlike a PC Alt+Ctrl+Del.) Press and hold the SETUP button, the control knob (button) and the upper right control button at the same time.
    Tony Smith
    Regina, Canada
    Back in a C7!
    Jul 15 2009
    CA
    Re: MMI issue
    This has happened only a couple of time @ the dealership. When the Q5 was launched, I was in contact with Audi Germany and MMI software engineers. I had one just last month. As of this time Audi doesn't know what is causing this, but they are working on it. When I test all MMI systems with the scan tool, everything checks out OK. Just take it into your local dealer and see if they can call Audi Tech Assistance and let them know there is another Q5 with this issue. The more cars they know about, possibly the faster they will find a solution. Hope this helps.
